engine trouble!!!!
Tend87
Sep 26, 2005
guilford, Connecticut
hey...i have a 94 talon..(non-turbo)...unfortunatly...but im having engine trouble and cant figure out whats wrong for the life of me
heres whats goin on....the car is like misfiring and really hesitent when i accelerate hard and when i go up hills and have to give it more gas...i pulled the plugs to see if there was somthing goin on in there and 1-3 were normal but in cylender 4, the plug had some pretty good carbon deposites on it. i thought that it might be an injector (which it still may) so i put some injector cleaner in it and ran it and that didnt work. it runs but not great. oh i can make it run smooth if i accelerate lean and not hard, but wheres the fun in that?...hahaha...i would love some suggestions because i have no idea whats goin on. oh its also a manuel tranny if that makes a difference. thanx a lot
-steve
check for a ground in your wires, had that happen alot with my n/t's dont buy autozone wires they usually ground out in a couple months not hard to change but just a pain in the wazoo. you can check if they are just by getting a spreader and running with it on and if it dont happen change the wires keep them away from anything to ground them out.
^^^yep what he said.you said it was hesitent also check your fuel filter
and run an ohm test on the injectors
