Engine Rebuild ?s
krustindumm
118
Oct 17, 2002
From the top, engine burned oil real bad (like 1qt/day and cyliders 1&4 were so full of oil/carbon it flaked off the piston tops in sheets), especailly at startup, dignosed as the rings because it has a rebuilt head and a new 14B. So I tear it down and send the block to be checked out. The oil control rings were almost solid w/ carbon and they did not expand on removal, bores looked good.
Just got a call from the machine shop, they had to deck my block .006 (6 thousanths). The bores were fine so they just honed it.
This has me worried that I diagnosed the problem wrong. Maybe headgasket? A faulty rebuild on the head? Defective turbo? IDK im kinda worried that I'll get it back in and it will still burn oil.
Also how much will the decking rais compression and throw off my valve timing?
Thanks,
-Dustin
[mod: please move to extreem tech if needed, thanks]
1qt/day is "more than a lot" . Stuck oil ring cause excessive oil consumption and they can get that way because:
1 Frozen rings after cylinder is flooded with coolant
2 Combustion gasses get by both top rings
While the first scenario does not mean cylinder wear too, the second kind of implies it. Rings get worn out faster than the cyl bores but to have that much oil consumption is really hard without having the bores worn and/or out-of-round because of bad overheat or too many hard miles.
Also a head that did not have the guides worked on causes excessive oil consumption. Guides can be cracked by bent valves or just worn out.
Bottom line it may be one thing or more combined.
.006" material removed will raise the compression by .06 so you shouldn't be worried.
Mitch.
