electric problems no idea
240kid
153
Dec 19, 2004
downingtown, Pennsylvania
i just bought a 95 gsx shell and put a 6bolt into it. the following items dont work due to some electric issue, driver seat, mirrors, headlights, blower, windows. i swapped body control modules from my other 96 gsx are they compatibale? checked all grounds and they are good. none of the wires look touched under the dash. any sugestions? the car starts but no power to other things mentioned above
95-96 modules are not the issue, unless the swapped module is defective. You're going to have to just double check your work. Check the wiring again and make sure you didn't pinch any wires. Of course check any fuses or relays.
Also, do NOT re-post the same issue twice or bumping your own thread (though you didn't do that).
http://dsmtuners.com/forums/showthread.php?t=250886&highlight=electric+problems+no+idea
If someone knows the answer, they'll let you know.
  • Wanted 6 bolt NT water pipe
    • chrisman287
