DSM Timing Belt List (Includes ARP #'s)
midnght
2,446
Nov 14, 2002
Hagerstown, Maryland
My 1997 GS-T Timing Belt/HG replacement list. I'm sure this is all the same for the others, with some changes here and there if need be.
I have looked around for a list like this but couldn't find a total list anywhere. This list is includes ONE non-factory item, the ARP's. The reason I posted it was because I found them cheaper than any part site that we have listed anywere. Use these numbers to order or search around the net. Enjoy:)
#207-4203 95-99 ARP Head Studs (11mm - 12-Point Nuts)
#207-4201 89-94 ARP Head Studs (12mm - 12-Point Nuts: Includes VR-4)
MD972050 Water Pump Kit (Pump, O-Ring, Gasket)
MD349347 Mitsu Metal-Layered HG (Not the EVO VIII HG, that is a different OEM Part #)
MD372536 Cam Seals (2 are needed)
MD186785 Spark Plug Well Gasket (4 are needed)
MD186784 Valve Cover Gasket
MD050536 Half Moon Gasket (1)
MD326059 Timing Belt
MD182537 T-Belt Tensioner Pulley
MD308086 Auto Tensioner
MD156604 T-Belt Idler Pulley
MR984778 Balance Belt
MD192068 B-Belt Tensioner Pulley
-or-
MD103722 Balance shaft Bearing (Rear)
MD040597 Balance shaft Bearing (Front)
MD092785 Balance Shaft Cap (Plug)
MD098626 Balance Shaft Stub Shaft
