Driveability/Weather
16gevoiii
Jan 2, 2007
south bay, California
I have been trying to figure this problem out for awhile now using the forums as reference.
car has good power and drives good for the most part>the problem is depending how the weather
is that day determines how smooth the car drives.
anybody else having this problem?what were your findings?
thanks!
First check I would make with any drivability issues is a boost leak test. Buy/build an adaptor to attach to your turbo, pressurize the intake, and spray any suspect areas with soapy water to see if there are any leaks.
What is the exact problem you are having? Runs better when warm? Cold?
i have no boost leaks,
basically driving on days when its not to hot seem to be good,then say next day seems the same but its not cause i as i accelerate it misses until i give a tad more gas and it will go away.
i changed my unhacked Maf twice thinking it monitor air temp and it help i little.
any ideas
thanks for input!
