Drivability Issue Please Help
DSMTalonAWD51
169
Apr 3, 2005
los angeles, California
Hey guys, hopefully someone has had this problem before and knows what it is.
This started happening yesterday all of a sudden. When I drive lightly around town, everythings completely normal. When i drive at WOT the car accelerates normally ( i am boosting about 16psi). When I drive the car under 'partial' acceleration with the gas pedal about half way down, my boost starts to rise ( builds up to between 5-10 psi) and the car gets louder, everything 'sounds' like i am giving it some gas but it does not accelerate, it kinda hesitates as if something is slipping, almost feels like a slipping clutch. does anyone have any idea?
i ruled out the clutch, it feels completely normal, and all vacuum lines are fine. since it accelerates great under WOT I have no idea what could be causing this. I thought maybe the o2 sensor may be acting up because i noticed that even during light driving my air fuel guage is going over to rich when it used to just bounce around until i gave it a lot of gas. but i figured if it was my o2 sensor i would have a check engine light.
someone please help thanks!
(its a 97 gsx, 16g, 1gen block/2gen head)
I'm not too experienced but from what i've read it sounds like you might have a problem with you blow off valve or the BOV return line so try to check that out. Good luck. :dsm:
How experienced of a driver are you? Example: If you are in 3rd gear, trying to go up a hill and only at say 1800-2000 rpm and try to accelerate, your boost with go to about 7-10 psi and it will feel like you are not going anywhere...But yet if you shift into 2nd gear you will not have a problem climbing the hill
I think that makes sense...If not someone correct me...But i believe that could be a POSSIBLE problem
naa this isnt a 'lack of power' under acceleration issue, it feels like there is something slipping. this happens on completely flat roads between 3-5k rpm but as soon as i floor it the car will accelerate fine. it does almost feel like maybe the bov could be leaking but i have had it for 3 years and never had to adjust it for any reason. and i also checked the vacuum lines... :confused:
