Do I need a camber kit?
TsiBoosted4g63
93
Aug 16, 2009
Cherry Hill, New Jersey
When i got my car it was already lowered with kyb's and the rear camber is really bad. I heard that I needed a camber kit and then i heard i did not need a camber kit. Can anyone help with this? If i do need a camber kit what exactly do i need i have been looking and it seems that there is a lot that you need.
On 1G's, excentric bolts on front but you need adjustable upper arms (ingalls) or an excentric bushing kit (DME) for rear.
+1^
I have eccentric bolts in the front and I just installed these adjustable rear control arms from 3sx.com. They went in very easily, were extremely easy to adjust and completely eliminated all camber issues in the rear end. I still need to get a professional alignment, but the rear tires aren't riding on the inside edges any more.
+1^
The price listed on 3sx is for only ONE arm or the pair?
Even in the part description it says for 3000GT and Stealth, i'm guessing you had to call up and order some for your 1g? Or is it another miracle that the control arms for 3S mitsu's are the same as 1g dsm's???
Just order the same one's for the 3000GT VR4. They are a direct replacement for the 1G DSM camber bars and fit perfectly.
Another supplier of camber bars can be found here at Maximal Performance. I was told that they come with all new hadrware so you don't have to reuse old or rusty hardware.
