jking29
- 656
- 8
- Jun 7, 2005
Huntsville,
Ohio
Ok, I just got through pulling my trans out and putting a new Spec stg 2 and Act flywheel in. While I had it out I put in a Phantom Grip in the trans. Here in lies my problem. I bought the lsd used and already installed into a dif for a good deal from someone going to AWD. I'm not sure what year of trans it came out of, but the dif appeared to be the same with the same bearings and such, and just took my ring gear and put it onto the new dif and installed it. Everything went back together great until I went to slide the axles back into the trans and just got a solid clunk. It appears that the inside diameter of the dif is about 1-2mm smaller than the axles. I have been searching and find out that 90-92 trans had a smaller axle. Can anyone tell me the diameter of the different axle shafts? Do you think I will have any problems running this dif and getting the smaller axles, as I really need to change mine anyway? Any info or help you have would be greatly appreciated!
