Denso or Champion
danyz250f
631
6
Mar 13, 2005
Rexburg, Idaho
Which would be better to use, I currently have the spark plug options of: denso W20EXR-U11(little bit fried on top or champion RN9YC
The general consensus here is to use NGK BPR6ES for a mostly stock car, and BPR7ES for a more modified DSM. Run .030 gap if you're boosting 18 or so psi or less, and .028 if more.
Sucky ### thats all the parts stores had. I will have them order some new plugs. So I have a slightly modded car so should I get the ngk 7 s or the 6 s and which one is colder.
I replaced my plugs today, and what did I find, champions, I put some NGK platinums and it runs way better. Champions suck
I would go with the NGK BPR7ESs because you are slightly modded, and like eclipsegsx1736 said gap them .030.
DragSourceTsi said:
I hope your not moded those plugs suck. Just normal ngk
I have not done much to my car yet, I bought them cause thats all I could find at the time, they are still better than champion
