1G Cyl 3 spark, fuel, compression but no fire
awd_some
69
4
Jan 2, 2007
Lexington, Missouri
After swapping a unknown but supposedly freshly rebuilt long block into my 94 Talon ES 2.0NT, I’m having an odd issue with cylinder #3 not firing at all.
What I’ve tested/tried:
Full 150+ psi compression on all cylinders
Plug wire is making plenty of spark
Injector has been swapped out with others and confirmed good
Injector is ‘clicking’ so it appears to be a hood harness & driver
Swapped a few different plugs in and it does look pretty dry after cranking for a bit.
At this point I’m looking for a few fresh ideas to try without spending a lot of more time on this NT
You have a good injector, but a dry well and no firing---I would stick a noid light on that injector wire to make sure that you're actually getting a signal and it's firing.
I'm guessing you'll be back-tracing through the system (wiring, ECU, CAS) to figure out why the injector *isn't* actually firing.
  • For sale 1g 4 BOLT Manual LSD Rear Differential
    1G 4 BOLT Manual LSD Rear Differential $225 + shipping & paypal feesYou must be registered to...
  • For sale 2g NEW STM Water Pump Block Off Plate
    NEW 2G STM Water Pump Block Off Plate $35 + shipping & paypal fees* these are $49 onlineYou...
  • For sale 4G63 NEW Greddy Shift Knob
    NEW Greddy Shift Knob $50 + shipping & paypal fees* these are $90 onlineYou must be...
  • Wanted 2g WTB CLEAN HVAC PARTS
    Good condition , clean please no rodent infestation
    • ames905
  • Wanted 2g MB914045
    I need a driver door trim piece.
    • T’sGST’s
