Crankshaft Sensor
knonitz
Nov 11, 2009
mcallen, Texas
does anybody know if there are supposed to be different Crankshaft Sensors for the 95 talon, I think mine is giving up but I can't find one for my car. the ones I found have different plugs. I checked autozone, oreiley, advance and several others but the connection is different
What shape and how many wire's is yours? Should be an oval 3 wire right about the oil filter. Yellow-Black/Green-Blue/White. Here is testing procedure.
it looks cracked so I think is faulty, it can still run but want to replace before I really have to change it, but wherever I look they only have the rectangular one. the one they have have the pins a bit more wider(- - -), mine are only pin like.( . . .)
I already took it off, and saw it, and tried it, (doesn't work) i can cut the wires and put the sensor with the harness, but I wanted to avoid that
I just went through this issue, all crankshaft positioning sensors are the same from 95-99, should have long mounting tab and a triangular plug, here is a picture of what you need.
That's a turbo one. Wrong car. What colors does the one you bought have?
there is a photo but I don't if you can see it put it as attachment.
Does your have any numbers on it? Everything 95 showed the blade not pin style.
I don't know, I am at work so can't check it right now
got another '95 as well, I checked that one and has the blade. of course someone replaced the harness before since the cables have been cut
I got a '95 eclipse and '95 talon. the eclipse has the replace harness, the talon has the original harness which I have to change since I can't find the sensor that I need. I didn't want to mess with the harness but I guess I have no other choice
Yes change it to the harness it SHOULD have. Then get the correct CPS.
the talon which is the one I have to fix has the original harness, and the sensor that I need to find. the eclipse has the "changed" harness and the one with the right sensor
Get the colors off the changed harness and I will see what it came off of.
gonna change the eclipse harness to the talon and see if I can find another harness in a junkyard. easier than finding the sensor
here's the sensor that was on the talon, it seems damaged. I have been looking up any information on it but I can't find any. have you by any chance seen it before? I got the part # or at least i think but when I look it up I come up with nothing. the #s it has are: on top 1505, lower part 377 47810.
  • For sale 1g 4 BOLT Manual LSD Rear Differential
    1G 4 BOLT Manual LSD Rear Differential $225 + shipping & paypal feesYou must be registered to...
  • For sale 2g NEW STM Water Pump Block Off Plate
    NEW 2G STM Water Pump Block Off Plate $35 + shipping & paypal fees* these are $49 onlineYou...
  • For sale 4G63 NEW Greddy Shift Knob
    NEW Greddy Shift Knob $50 + shipping & paypal fees* these are $90 onlineYou must be...
  • Wanted 2g WTB CLEAN HVAC PARTS
    Good condition , clean please no rodent infestation
    • ames905
  • Wanted 2g MB914045
    I need a driver door trim piece.
    • T’sGST’s
