1G Coolant leak near water pump elbow
tarheels23
101
May 15, 2011
struthers, Ohio
So I was putting my transmission back in and since i was using floorjacks the part of the transmissiong would keep pushing on my water pipe and causing coolant to leak from the corner where the water pump meets the coolant hose, how do I fix this and what type of o ring do I need. Id rather replace it now while I have all the coolant drained out.
Does the water pipe just twist and come out?
Here is the part number. You can find it on many retailers like ExtremePSI, JNZ, MAP, etc...
- OEM Stock Replacement Water Pump O-Ring
- Fits all 90-99 Turbo DSM
Part Number: MD030764
