Compression ratio with E85
mikejames27
41
Sep 13, 2009
Portland, Oregon
Alright, Ive decided on Wiseco HD .040 over pistons but now have to decide on compression. Car will be run strictly on E85 until I get an aquamist kit on. Turbo will be FP HTA GT3586r. Can I get away with 10 to 1 compression running straight E85? Im looking to run about 22-25pds DD. Then use the aquamist 50/50 water/meth at the track with much more boost. Im trying to find out as much as I can since im ready to order. Thanks!
Most likely I'll have 10:1 next year; ripping the engine apart or building a new one will be a good winter project as I will otherwise be tempted to drive it in the winter again and have more rust sprout up underneath like last winter. My rings are probably pretty worn anyways as I only have around 140psi of compression.
I am running 11:1 with E85. The car made 533hp and 385tq on 20psi at 7800rpm. It actually made 554hp when I rev it to 8400rpm. I think it will make more but i ran out of time on the dyno and did not get a chance to really tune the time more. i think at 23-25psi, it will put out 600hp with no problem.
I am running a gt3582 on a 2.0l. aem ems, forrester intake, custom exhaust manifold, old school crower stage 3 cams and valve trains, chinabay stainless valve, bronze guides, home ported head, wiseco 11:1, eagle rods,
Go with the 11:1 or even 12:1. This way you can get a cheaper non ball bearing turbo to make reliable hp. High boost on non ball bearing turbo usually means premature thrust bearing failure. Also you can get away with running a smaller intercooler because you won't heat the intake air up with the high boost.
I myself have 10:1 compression ratio in my gst and I run straight e85. As far as turbo goes, I have a Holset H1E but I have yet to tune to its full capacity. I will update here when I actually get a full tune. I am running 1000cc injectors which might be my downfall.
