Compression is 180 across
Status
Not open for further replies.
Geo2g
72
Feb 18, 2004
Queens, New York
But I don't make any power. Could it be the Web cams? I put down 240 ponies to the ground and I am using agp's L2r with all of the supporting mods. 6 months ago without the cams I put down 304 ponies with 110 120 120 130 compression. Someone please help!
Vpc Gcc 660 chip
660 denso injectors
Agp's L2r
VP's O2 housing
N1 turbo back
Ported 2g Manifold
Tial 46mm waste gate
Built Bottom (JE&Eagle)
Stock Head
Web Street Grind Cams
Spearco 216 core with aluminum piping
Tial BOV
Compression in each Cylinder is either 180 or a little more.
With all of this crap I dont make power! 240 to the wheels. For some reason I think its the cams, because thats the only thing that is new in my setup. HELP!!!!!
Turbo could be taking a crap?
180 compression is high isn't it... I thought it was 164 stock... or maybe its for 1g's or maybe I was told wrong altogether
Boost leak test? make one, use it...
It cant be the Turbo. It only has about 5000 miles of use and no abuse. How do I make a boost leak tester?
I don't see a fuel pump/AFPR listed there. Do you have them?
If you're on the stock fuel pump, that is more than likely the problem.
EDIT: Nevermind, I just reread your original post.
Pull the intake off and see if the compressor wheel on the turbo has any 'play'.
Ok! I just ran home for lunch to do the leakdown test. I put the motor to TDC. Pulled all the plugs and inserted the compression tester hose to the spark plug hole. I hooked up the compressor to each cylinder one at a time and nothing leaked out. No bubbles in the antifreeze either. Any other ideas. Thanks for the help so far.
i think it might be your windshield wipers,i would def. change those asap.i changed mines and i felt the throttle response much faster LOL.by the way u dont need this post no more,we got the car fixed !!!!! any hondas wanna run tonight holla at my ##### george
Status
