70 compression across
sTeCz|GsT
Nov 13, 2005
Kearny, New Jersey
ok so i randomly decide to to a compression test of my motor and came to the conclusion that starting from left to right cylinders the compression of each was 70 75 85 and 95. now i know thats kind of low how should i go about this problem?? :confused:
Did you do the compression test with a hot engine or a cold one. To get proper readings you really need to beat on the car for a bit before you come back and do the test. If you still have bad readings, pour a cap full of oil into each cylynder and try again. If you get better readings your rings aren't sealing properly. If you still have bad readings perform a leakdown test to see where you are loosing compresion.
