Clutch recomendations
RichardB
104
4
Jul 28, 2008
Rotherham, Europe
Guys
I'm looking for a clutch and flywheel for my Drag Mitsubishi FTO that can handle at least 750lb-ft. We’ve put a 4g64 engine in running an FTO gearbox. The EVO I-III 7 bolt 225mm flywheel will mate up nicely so what I'm actually saying is I need a clutch and flywheel for an EVO I-III that will handle at least 750lb-ft. What would you recommend?
Take a look at Southbend clutches. I'm sure they'll have what you need. You can piece together everything you will need for the power you have.
Southbend would be my choice for a Single Disk Clutch, but you Sir might want to take a look at a Twin Disk. Both clutches I speak of can be found at TMZ Performance I have spent a couple paychecks here and believe me Tim Zimmer has some of the best customer service I have experienced. He will be straight foward with you. Just an option. Hope this helps.
    • Sdcryan1
