changing valve seals
latitude84
Feb 22, 2012
vancouver, Washington
I'm not sure if this is the right place but I need help changing the valve seals. If you have the resources to do it let me know. I don't have the air compressor or adapter needed to do it with the head on.
I may know somone that can do it for a cheap price and have all the tools. In the head is always a little more work but its doable. Let me know.
Just need a valve springs compressor remove the keepers and the spring out of the way to install the valve stem seals right? Did you buy all blue viton valve stem seals?
Sears has the tool you need its pita tho hope you have patience and a clean organized working area keep all the parts in its corresponding order. i would almost just have a machine shop do it good luck.
