car stalls out when it gets warm 91 talon nt
talonbolen
Aug 17, 2008
medicine Hat, AB, Canada
we changed the fuel pump and filter and its like the motor isnt getting fuel when warm it will just shut off and you can start it and it will rev up for like 3 seconds and then it will stall no idea wats happening its like the injectors arent getting a signal or something
Check and see if it is getting spark after it warms up and is dieing. And if it has spark dont assume it will run correctly, it could have spark but the spark could be out of time(if that makes sense) Im not 100% sure about the components on you car but on a lot of cars there is a little ignition module=. When the ignition module is starting to fail, it will work until the engine warms up. Ford had ignition modules for years that worked fine until the engine got warm and then it would die. Check your serivce manual or look at a wiring diagram for the ignition system to learn about this module. On my 2gen turbo the ignition module bolts to a little metal bracket that mounts near the fuel rail.
My bet is that your problem is ignition related. Most fuel problems are evident all the time. Some fuel pumps will start to fail when they are warm (if the pump is old) but you said you replaced it. I hope this helps.
