Can't lift the head off to save my life.
well you could try a 1 ton lifter by ataching it to the valve cover coblts, and pull away!
no seriorsly, on the back of the intake mani, there are two bolts connected to manifold, that holds on a bracket to the block, used to support the intake manifold. there is onle bolt on the block, but its easier to take the two bolts out of the back of the intake manifold.
Check the intake mani bracket that connects to the block and make sure it is off. Also you may want to have someone help you lift it off, because it can be a pain to lift off if you don't lift it off straight up. Hope this helps.
