Breather Valve?
Don't let a bunch of water in there though, engine oil and water don't mix well and it could do damage to your bearings, a little bit wil probably be okay but if you are allowing water in there often then that is a bad thing. I assume this is in connection with your catch can project but some more information would be helpful to know how much of a problem there might be. If you are just talking about having a filter on the end of it then it really isn't any worse than having a bad vc gasket or running an open element air filter. If you are for some reason squirting water into your breather then thats not very good. Keep in mind also that one way to reduce carbon buildup on an engine is to stick a vacuum line in a can of water (or automatic transmission fluid) and rev the engine.
No, I blew into one of my catch cans lines to check if it was airtight, and you know how you get condensation from your breath, well I started it and it went just fine.
Thank you for your fast responses :)
the_mork said:
nope, it takes quite a bit of fluid to hydrolock an engine.
You don't need a lot of water to hydrolcok a cylinder. You only need enough water to fill the cylinder when the piston is at tdc. If you have enough to fill it up when it's at tdc the rod will most likely bend from it since liquid can't be compressed.
  • For sale 1g 4 BOLT Manual LSD Rear Differential
    1G 4 BOLT Manual LSD Rear Differential $225 + shipping & paypal feesYou must be registered to...
  • For sale 2g NEW STM Water Pump Block Off Plate
    NEW 2G STM Water Pump Block Off Plate $35 + shipping & paypal fees* these are $49 onlineYou...
  • For sale 4G63 NEW Greddy Shift Knob
    NEW Greddy Shift Knob $50 + shipping & paypal fees* these are $90 onlineYou must be...
  • Wanted 2g WTB CLEAN HVAC PARTS
    Good condition , clean please no rodent infestation
    • ames905
  • Wanted 2g MB914045
    I need a driver door trim piece.
    • T’sGST’s
