bolt size?
EVOL2003
45
Oct 25, 2007
PLEASANT PRARIRE, Wisconsin
ive searched, but with no luck. the threaded bolt that the oil filter screws onto is loose and leaking oil, what size is this bolt? not sure of the correct name for this bolt. maybe oil housing bolt. please help
If you are talking about the socket size it's a 24mm
Don't tighten it too tight or you will crush the insides of the oil cooler and coolant will mix with your oil.
thanks man. yeah the socket size is what i needed. do you happen to know what to tighten it to? in foot pounds
