Bad Compression
joobienooner
May 26, 2006
Ypsilanti, Michigan
Well I just compression check my 91 talon tsi and the results are 30-115-130-140 (1-4). Car was warmed up and I test at WOT. The car only has 9XXXX miles and has always been completely stock and run at stock boost. Dont really know where to start and I dont have a leak down tester. Could it just be the hg or does it sound like something worse.
Thanks,
Ryan
Could be variety of things, HG, your head, piston rings etc. I believe at this piont its too much of a guessing game and you need to diagnose some more, good luck.:thumb:
It seems weird that the compression gets better as you go to the next cylinder. Could it just have a crack in the headgasket between the cylinders or something like that. The car only has 9XXXX miles on it, I would hope that it doesnt already need a rebuild.
Thanks
Ryan
put oil in the cylinder and re-test if it stays the same then its probably a headgasket or valve. if it goes up its rings. oh and worse case it might be a combination of both, unfortunately 1g cars run pretty agressive/lean from the factory and if there are any boost leaks it can cause some damage so even if the car was bone stock without making sure it was in perfect running condition problems can occur. btw try all cylinders with oil during the re-test cause one may not change and one might. it sounds like you are in for a rebuild, altho ive had ppl bring me cars that have been running on two dead cylinders LOL. so it might last a little while but you risk causing more damage.
Alright so this is weird. I Decided i was going to do a cold compression test and then add oil and do another cold test and see if it went up. But the cylinder that was 30 yesterday when i did the hot test is now 120 cold. Is there any reason why it would be a lot less when its hot? Also yesterday when i found out cylinder 1 was only 30 i tried cylinder 4 again and got 140 again, then i tried cylinder 1 again and got 30 again. So the gauge is consistant. IUNNO. I'm kinda scared to drive it.
Thanks,
Ryan
  • For sale 1g 4 BOLT Manual LSD Rear Differential
    1G 4 BOLT Manual LSD Rear Differential $225 + shipping & paypal feesYou must be registered to...
  • For sale 2g NEW STM Water Pump Block Off Plate
    NEW 2G STM Water Pump Block Off Plate $35 + shipping & paypal fees* these are $49 onlineYou...
  • For sale 4G63 NEW Greddy Shift Knob
    NEW Greddy Shift Knob $50 + shipping & paypal fees* these are $90 onlineYou must be...
  • Wanted 2g WTB CLEAN HVAC PARTS
    Good condition , clean please no rodent infestation
    • ames905
  • Wanted 2g MB914045
    I need a driver door trim piece.
    • T’sGST’s
