backfiring after engine shampoo?
kmj 4g63t
219
4
May 8, 2009
montreal, QC, Canada
Hey guys, I cleaned my engine bay today and covered all loose wiring and have the valve cover over the spark plug wires. I washed everything dried it and waited about 2 hours before turning it on, once I did it started to smoke and it backfired.
I turned the car off took the wires off, checked each one and dried them properly and checked around for anything wet and dried it. After doing so I turned the car back on with no smoke coming from the headers, it now idled fine but after 5 minutes it backfired(I do have a full straight pipe with no muffler). That hasn't been a problem as of yet. Is this backfiring happening because my spark plug wires are still wet or is my engine not running on all cylinders.
I checked around the forum and no other person had this trouble after an engine shampoo. I don't want to drive my car until I find out whats up with it.
Thanks a lot guys!:thumb:
I have seen this with other cars. The throttle position sensor holds moisture like a SOB. Unplug it and take it for a drive. It will kick on the CEL but it will still run. See if it stops your problem.
Fixed the issue and figured out why my car was sputtering. It's the Maf and it was caused by my old filter that was disgustingly dirty. 2 Mafs in 4 months caused by the same dirty filter.
Buying a new maf and I have a new filter(problem solved).
