Angel Eye fog lights on a 97+?
I finally managed to create one of those for my projector headlights. It took some time but is possible to do. See it in my gallery. I deleted the thread that I created for this post before tho. So if you search for it, its now gone. Thank You Shuwa for the info you shared. :thumb:
Charmer-
How did you wire those up to turn on with your low beams? Do they stay on when your high beams are on too?
the wiring wasnt hard at all. Once I mounted the optical fiber to the high beam compartment, I connected the wires to the existing side marker light's wires (tapping power from the side marker). Yes, it will stay lighted up when the high beam is in use but you wont be able to see it since the high beam is much brighter :)
  • Wanted 6 bolt NT water pipe
    • chrisman287
