AGP RS49T wheel size
madman
472
3
Oct 9, 2003
Kansas City, Missouri
Does anyone know the Inducer and Exducer specs of the Turbonetics wheel?
I have a RS49T and want to put in a different CHRA in a need to know if it will fit.
I think I'm ok on my turbine side specs.
I've seen those numbers on other turbos too, so I guess most all 50trims are the same?
I was thinking of doing that to my RS49 too. and installing a 57 trim BB chra.
I thought, with my luck id buy it and the thing would touch the housings somewhere and they would not take it back.
Ive also wondered it theres CHRAs use and o-ring on the compressor housing, and if the Turbonetics cover would seal right if the CHRA has an oring in the kit.
I have also thought about this angle:
New PTE turbo: 1200$ ish + sell old turbo for 450$ or so. im out like 700$ and everything works.
Vs, buy CHRA 660$ and take the old stuff apart, hope it all fits and works:(
I think id rather buy a new one:rocks:
The compressor wheels are the same size. The only thing with a different brand is the compr/turb housings. So if something says "50 trim", that means it'll be the same size. 57 trim, 60-1, etc. are all the same from different companies.
