Aftermarket Gauges
EclipseGS4651
86
Sep 5, 2003
Framingham, Massachusetts
This is kind of a random question but I bought some neon blue aftermarket gauges for my 95 non-turbo eclipse probably about a year ago. As probably everyone knows that has experience with the non-turbo gauges, all the aftermarket ones only go up to 8000 RPM and the stock ones go up to 9000. To get to the point, I am trying to figure out where the 7000 RPM stock redline is on my aftermarket gauges. I think it is around 6 grand cuz I believe I once bounced off the redline around there, I would just like a definte answer. I may just take them off to solve all problems but I figured I would ask if anyone knew before I went through the process of removing them. Thanks in advance.
you could take both gauges and mark there redline is on the stock ones then overlay the new ones and do it that way. also you could take a picture from the same angle of both gauges and photoshop it to see where the match up. there are many many ways to figure this one out
