AEM AEM EMS 2Step Settings
talont3t4
416
Feb 9, 2003
Edmonton, AB, Canada
Anyone have any good setting for a large turbo using VS not a clutch switch. Thanks Ron
Are you trying to use it as anti-lag or as a true 2-step? If you try and run it as anti-lag you will have problems with the engine trying to make way too much boost. I would use the anti-lag setting for that.
You will just have to play with the setting and see what the car likes. Just remember to set the ing side of the 2-step retard rev way higher than the ing and fuel cut or it will act like anti-lag and the boost will run wild.
Polk
