AC (Unknown wire identification)
the reason i think its the ac climate control wire is b/c i followed it back to the fuse wire..and its the same color.
Ok, I viewed the link and it makes sense. Where it connects between the oil pressure gauge sender and the connector, can I splice the wires together instead of connecting?
BTW, do you see the other wire behind the clipped one? That's also unknown. I'll see what the color is and post it.
Yes you can splice there. So your oil pressure gauge must not be working then.
Where does the other wire come from (what harness with what other wires in it) as well as it's color? Also can you provide a closer picture?
Late response, hopefully you still look in here. That unknown wire comes out of the the alternator harness. I'll have to post another pic but I think it is yellow and green. Don't take my word for it though, I'll know for sure when I double check.
