A/T Fluid Suggestions
thegame
Oct 1, 2002
Clinton Twp.,
So I did some searching and found alot of recommeded fluid for a M/T (syncromesh, sycroshift, etc.). But since I have an auto does anyone recommend a particular fluid. What is the difference between Auto and Manual fluid? Can Manual fluid be used in an auto or will I screw it up? Suggestions?
Thanks
I always use chrysler atf+4. It says to use atf+3, but there is no difference, they bump it up every couple years. You can get it right at the dealer for about the same price as the parts store. I like the dealer fluid, it gives you a better feeling when you put in exactly what is supost to be there. But before you take my advice, check in your manual, or ask the dealership just to be on the safe side. :thumb:
Steve.
