96 gst clutch pedal on floor
gst2ltrv8eater
Nov 19, 2004
blasdell, New York
my clutch pedal just sticks to the floor, i have bled the hydraulic lines and still nothing, clutch pedal is right on free-play. im thinking that it might be the connecting rod for the clutch pedal, either with the spring or its just broke...also was thinking the slave cylinder might be shot.
any help would be appreciated.
~wnygst
chris
gst2ltrv8eater :dsm:
Are u leakin clutch fluid?
when u press the pedal does the clutch disengage?
when my pedal stuck to the floor.. my master clutch cylinder was shot... I replaced it and everything was dandy..
just had a leaking slave doing that.... almost got stuck in chicago. If the fluid isn't where it should be (normal fill/your last fill) you are probably leaking. If you see ANY fluid on the rod that goes through the firewall from the clutch your master is going.
I bought my car w/ the problem of the clutch pedal on the floor. I put in a new master cylinder, New slave cylinder and a stainless steel clutch line. None of which was the key. I had a blown clutch.
