6 Bolt Swap help in Youngstown
Pitbull2o08
88
Feb 7, 2009
Fayetteville, Ohio
Is there anyone that can help with the finishing touches of a 6 bolt swap in a 1998 GST? I'm new to dsm's in general so any help is appreciated.
Thanks
i might on sunday. fitting the flywheel and dropping it in. custom CAS is what i'm confused about still. it seems too simple. plug it in, connect blue wire to white wire.
it really is that simple! did you get the RRE version?
yeah it wasn't bad at all. it's all swapped in now and running fine. I'm going to be rebuilding my e316g and replacing the worn t25. i'll post pics later
almost done
all cleaned up
How can i fix these headlights so they will be brighter and not have the light impeded by the plastic housing?
the best way to remove the yellowing of the headlights is to progressivly wet sand. Start by using 500 grit paper on a da sander. Then move to 1000 grit, then to 1500 or 2k. Finally buff with a rotary buffer with a good polishing compound. (I have had good results with system one) Available at most auto paint stores. Be sure to keep them plenty wet when sanding and to tape off around the lights to prevent any paint damage
  • For sale 1g 91-94 ignition coil
    1g coil with harness side igniter harness. Digging in a box of remains from a yard six bolt for...
  • Wanted 2g Finish My Project!
    I am in need of some big ticket items in order to finish my project. In my engine bay there is...
    • dhssoccer24
  • For sale AEM Series 2 Total Control Plug And Play Stand Alone ECU For Sale
    I am selling my AEM Series 2 plug and play, fully programable, stand alone ECU. I had bought...
    • LSM
  • For sale 2g 2g passenger side PW switch
    Passengers side PW switch. Good condition. Message 702-741-6987
  • For sale 2GB Factory Owners Manual For Sale
    I am selling the factory owners manual warranty info booklet, and maintenance booklet, all in...
    • LSM
