burldude
- 200
- 0
- May 2, 2004
Fort Bragg,
California
I just got done with my 6 bolt swap . I kept the balance shafts , I just didnt want to bother with removing it all . I swapped the rings out for some fresh ones cleaned the pistons and installed new bearings . The old balance shaft belt I could tear with my hands it was completely gone . I turned it over for around a minute to get oil pressure . I put the plugs in and it fired to life . I ran it for around 20 minutes at 1500-2000rpm and turned it off when it hit running tempature . I fired it up again and there was no problem . Today though I went out to start it and it wont start . I have spark and fuel !! What could be causing this ? I am sure that it will be somthing easy . Any way I put my body kit on and did some trimming to make it fit perfect . If any one has any ideas why it wont start please give me a hint .
^ That's about the level of Craftamanship I'd expect from someone who had it torn down to parade rest & left the Balance Shafts in - :thumbdown
