6 bolt rebuild kit tune up?? where can i find one
orzech
91
Aug 23, 2004
Honeoye, New York
i saw the SBR 6 botl kit but idk hwo good those parts are and stuff. here is the main thigns im looking for:
rings
all seals
all gaskets
water pump
oil pump
bearings
timing belt
is there anyother kit that has basically the SBR one without the pistons, and including the water pump and oil pump.
How good is the brand "topline" ?? That is what the SBR kit includes is all topline products.
and if the rings are bad, is it just better to replace teh whole piston too? THanks.
Chris
come on... someone has to knwo something about this. No one ever rebuilds a 6 bolt?????
2 of my friends have used the Topline kit and their motors have been running great...good compression, no leaks, etc...I'm currently in the process of putting together my motor and I'm using Topline and so far everything is good...about another kit I don't know...my advice would be to order both pumps, gaskets, etc from sbr but that might be just as costly as the whole kit...I would get the whole thing if you're doing a rebuild, good investment
Edit - You don't have to replace the pistons if your rings are bad, just rings but if you end up going with the Topline kit, I'd replace all old with all new included in the kit...
