For Sale 6 bolt engine with EVERY New-in-Box Part
Sun_Ice4
Aug 5, 2004
Toronto, ON, Canada
This is a 100% complete part list for a 6-bolt build. All brand new in box. As you go through the list, you’ll see no expense was spared.
I’m not getting into parting it out. This is pretty much an all or nothing sale. (If you wanted EVERYTHING, except the block, head, transmission and transfer case, I’d consider that. But no other part outs. Please don’t ask for individual parts. And don’t ask if I’ll sell just the head components, or just the timing parts, etc.)
I’m about 120 miles north of Detroit, in Canada. So, this is likely for those of you in mid eastern USA, who are willing to make a road trip.
My price for every part listed below is $6,700 USD. Firm.
NOTE: it may take me a day to respond to PMs, given my job. But I will get back to those who have serious inquiries. And yes, I’m aware that selling all this is a long shot, but maybe there's someone out there who wants a 'brand new 6 bolt'.
Here’s the list. OEM part numbers are included:
**Block 6-Bolt - blueprinted, bored, decked. Crank - grinded, polished, balanced. **
The following parts have been installed:
- ACL Tri-Metal "Race Series" ROD & MAIN Bearings - ACL- .01 Undersz
- OEM Oil Squirters: 1g. 4 complete
- ARP Main studs - ARP-207-5401
- GSC Power-Division Race Balance Shaft (eliminates any debate of removing it.)
- OEM Tranny-to-Block Bolt Kit - RTM
Manley Forged Pistons 6 bolt. comp ratio: 8.5:1. size: .020" over (85.5mm)
Manley "H" Beam Connecting Rods: - MAN-14021-4
ARP Connecting Rod Bolts - ARP-107-6001
** 2G AWD Transmission **
** 2G AWD Transfer Case **
I have no history on either of these parts.
**Head - 6 bolt (not machined)**
HKS MLS Head Gasket - HKS-2301-RM006
ARP Head Studs 6 bolt - ARP-207-4201
1/8" BSPT Plug - MS661140
Block to Head Locating Pin - MS471111
Kelford 264/260 Camshafts - KEL-1-TX264
OEM Camshaft Oil Seal - MD372536
OEM CAS O-Ring - MD619648
Fidanza Cam Gears - Black - 961999
ARP Cam Sprocket Bolt Kit - ARP-107-1002
Kiggly Racing 6-Bolt Crank Trigger Sensor (takes care of random misfire codes)
Cam Angel Sensor Blacktop (Brand new) - MD184529
**Valve**
Brian Crower Upgraded Valve Springs & Retainers - BC-0100
Brian Crower Valves *QTY 16* - BC-3100 BC-3101
Manley Performance Valve Locks - MAN-13016-16
Topline "Revised" Lifters - TPL3-LIF-MI6
Topline Rocker Arms - TPL-RAMI6
Supertech Valve Guides Intake & Exhaust
Supertech Valve Stem Seals - STC-VS-M6.6Kit
Valve compressor tool from Euroexport
91-94 Throttle Body (Rebuilt) -
FP Cast Exhaust Manifold - DSM Flange
Fluidampr Harmonic Balancer (Crank Pulley) – 630701
OEM Harmonic Balancer Bolt kit - MS240211
ARP Crank Bolt & Washer - ARP-207-2501
OEM Crankshaft Sprocket - MD326852
OEM Crankshaft (Woodruff) Key - MD008959
OEM Crankshaft Sprocket Spacer - MD128107
OEM Timing Trigger Plate - MD131241f
**ALL timing parts below are OEM**
Idler pulley - MD156604
Tensioner pulley - MD129355
Hydraulic tensioner - MD164533
Balance belt tensioner - MD115976
Hydrlic Tensioner Bolt - MD129350
Timing Tensioner Arm - MD130032
Timing Belt Tensioner Lever - 0241256
Timing Belt Cover-Lower - MD141454
Timing Belt Cover-Upper CLEAR
Timing Belt Covers-Bolt kit
Timing Cover Back Plate-Exhaust - MD130094
Timing Cover Back Plate-Intake upper - MD127142
Timing Cover Back Plate-Intake lower - MD129344
Full timing tool kit (bolt, tensioner, cam gear)
**ALL front cover parts below are OEM**
Oil Pump/Front Cover. Incld Seals - MD175762
Front Cover/Oil Pump Main Gasket - MD149393
Front Cover Bolt Kit
Front Cover Plug (Castle Plug) - MD125376
Dowel Pin Cylinder Block to Front Case - MS471104
Drive Gear (STRAIGHT CUT) - MD121120
DriveN Gear (STRAIGHT CUT) - MD125361
Oil Pump Sprocket - MD135005
Oil Pump Sprocket Nut - MD095237
Oil Pump Drive Gear to Bal Shaft Bolt - MD040758
**ALL oil parts below are OEM (unless noted otherwise.. a couple of RTM pieces)**
"Mighty Max" Forward Oil Filter Housing - MD122260
Oil Filter Housing Bracket Gasket - MD149370
Oil Filter Housing Bolt Kit
HLA Oil Pressure Regulator - MD167599
Oil Cooler Inner O-Ring - MD620908
Oil Pan - MD156465
Oil Dipstick - MD127058
Oil Dipstick Tube - MD306348
Oil Strainer - MD113024
Oil Strainer Gasket - MD183240
RTM Oil Strainer Bolt Kit - RTM-8308
Oil Return Flange Gasket - MR258477
FelPro Oil Pan Gasket - FEL-OS30460A
RTM Oil Pan Bolt Kit
Oil Drain Plug & Gasket - MD050316/7
Rear Main Seal Housing - MD040330
Rear Main Seal Housing Bolt Kit - MF140202
Rear Main Seal - MD343564
Rear Main Gasket - MD183243
Engine Rear Case Pin - MF472403
Rear Main Seal Separator - MD040332
**ALL water parts below are OEM**
Water Pump - MD972052
Water Pump Bolt Kit
Water Pump Gasket - MD169859
Water Pump O-Ring - MD030764
Lower Thermostat Housing - MD190339
Turbo Water Pipe - MD171059
Thermostat - MD997608
Thermostat Housing Gasket - MD145038
Water Outlet Neck - MD130457
Coolant Hose-LOWER - MB605486
