Masteer E 25
- 128
- 0
- Aug 17, 2004
Philadelphia,
Pennsylvania
Can u put a 4g63T in a 1994 Probe.....can it be done or do u think it would be 2 much work.....
spyder97gs said:Yeah, you would be much better off to swap the KLZE motor in and then add a turbo. Just swapping motors bumps the HP up to 200, adding the turbo significantly increases that. It would save you a bunch of money.
Defiant said:Be sure to bend your knees and keep your back straight. And I'd get help, a Probe hatch has almost as bad a lift-over height as a DSM. Careful in closing the hatch, I'm afraid you might hit the glass when closing it and it only takes a little pop to make that glass turn into an instant glasschunk-shower.
And any fluids that leak from a 4G63T will eff up the cargo space carpeting, so be sure to take precautions. Use heavy tiedowns, that thing will want to roll all over the place and bash the plastic trim.
You'd be better-off just renting a pickup than ever considering anything as hammerheaded as trying to put a Mits motor in a Mazda. But yeah, the car's bigger than the engine, so supposedly you could waste enough time and money to do it.
. Putting a 4g63 up front and getting a starion tranny? Just an idea.
sherloc123 said:not many people caught on to defiants post yet
Royalty said:that defiant is a funny dude. he should seriously look into writing for comedians
Masteer E 25 said:Can u put a 4g63T in a 1994 Probe.....can it be done or do u think it would be 2 much work.....
look at the location of tha tbov on that probe :laugh: , the car must not liek boost if it put down only 200 hp at 23psiITSME4G63 said:look at the location of tha tbov on that probe :laugh: , the car must not liek boost if it put down only 200 hp at 23psi
lawdaman said:Uh, he was putting down 200HP @16psi on the stock turbo. He's NOW running 23psi on a T3 (I'd love to see what your putting down now). My friend has a PGT and he beats all sorts of cars he shouldnt, esp from a stop. The car has a lot of torque (stock: 145hp; 190tq). As for putting a 4G63 in a Probe (any year)... Yeah sure you can use it... to haul the motor around in the trunk that is. Good one Defiant.
Not sure if you are talking about the 2nd Gen Probe GT, cause they had a 2.5 V6 164hp/160tq.
