4G63 into 92 Mighty Max
DaDDiYo83
Sep 24, 2009
Syracuse, Utah
What's good ya'll!?! I just recently picked up a 92 Mighty Max, I'm planning on running the 4G63 in this light weight love. However, questions did arise. I haven't picked up the motor yet because I was curious to find out if the OE trans will bolt up to my new power house? Is this just a bolt up procedure, or am I looking to get a little more complex with this swap? Nother question is; of course I will need the ECU, but am I going to need to locate a wiring harness as well or can this matchup happen on it's own? I know that this is probably a question for the tech forums, but being new to the site I suppose that I can't post there quite just yet. Any help would be greatly appreciated. Thanks!
There is soo much information jumbled all over the web for this swap.. You just need to seach on here and search google.. You might even try looking into dsmtalk and other dsm specific sites... You my freind, are going to have to look for this info.. I heard it is relatively easy...
Some mighty max trucks came with the wideblock 4g64. so you can't swap in a 4g63 or 4g64 that comes in the DSM and use the tranny [easily]. Which motor is in that mighty max? If it's the 4g64, I think you can bolton the turbo manifold. You'll just need a piston upgrade to make it reliable. Do some more research. . .
ProjectZero
Some mighty max trucks came with a narrow block 4g63 (g63b) or 4g64 (g64b): click.
Then if you get really lucky, somebody like myself may stumble on this thread (a few days late, ah well) and offer all kinds of good info. :)
My website is www.Hotrodcoffeeshop.com. There you will find probably 10-20 mightymax swaps at various stages of accomplishment. Oddly enough, I actually just wired a 4G63 into a mightymax yesterday, so if you have any questions feel free to ask. I am happy to help.
Also, check out :: Project Zero G :: (as mentioned above), it is an awesome site with tons of rwd 4G63 swaps.
Then while you are browsing around, sign up for Mightyram50.com also. There are a lot of good guys and gals over there and it is a must if you own a mightymax / Ram 50.
-Jeremy
(4g63mightymax on all the DSM forums.)
Hey 4g63mm I never knew about your website now but I am hooked. I have a 91 MM macro cab, currently looking to get my transmission rebuilt and over a year or so collect parts for the swap.
i'm going to bump this thread back up. i am also a new member to the site with a '93 MM looking to eventually complete a 4g63 swap.
