Incan
- 0
- May 30, 2004
St. Louis,
Missouri
So, I need wheels & tires wide enough to stick out 4 inches on each side for a dsm experiment: (the objective is skidpad, not slalom) http://cellcluster.net/turbo/renderings/
Now i'm willing to have the front be 1 or 2 inches less if that won't damage the center diff. If the tires are the same exact height, then is it ok for the AWD if they are of different widths?
What I can afford right now are mustang wheels and spacers (the kind that have holes for the stock bolts, and then use thier own bolts to attach the wheel).
So I think this will be sufficient 315 millimeters = 12.4 inches
This is the tire size recommended to fit these 10.5 wide mustang wheels. They claim a certain backspacing, but that didn't quite match my calculations. Perhaps it has something to do with the outboard flange?
http://www.mustangtuning.com/silver-deep-dish-fr500-wheel-17x10-5.html
I can do that cheaper using tire rack tires and discounttire wheels, but maybe mounting & balancing will cancel it out. I don't care about looks, because what I really want costs $1200 each for 17x11. Hence the mustang wheels.
Anyway, I can afford spacers, but 1 inch wide seems to be the limit. I'm afraid that won't give me clearance for the suspension, knuckle, etc. I'm going to try and get that ebay wheelspacer machinist to make me 2 inchers. I started doing extensive calculations and research and created a diagram. I'm not worried about fender clearance.
The only offset guide that mentions the flange: http://www.motegiracing.com/techzone/wheeltechdetail.asp?filename=wheeltech4#
