2g swap 16g oil return line problems, need bolt sizes
gfactor27
Nov 18, 2002
lansing, Michigan
hey all, i just dropped a 16g in a 2g gsx. I have a decent oil leak from the connection between the turbo and the oil return line. The thing is with using the stock oil return line, the bolt holes had to be filed closer, which is fine (dremel rulez) but the bolt size for the two-bolt-flange are not the same between the t25 and the 16g (and prolly 14b) What are these different bolt sizes?
thanks
:dsm:
I think they are 10mm. As for pitch I think if you go to pepboys just grab a fine threaded 10mm bolts from there selection of loose bolts.
