2g chrome spyder rims?
fast4g63t
41
Mar 6, 2003
rayland/smithfield, Ohio
Just wondering if anyone knew what is the widest tire i can fit on a 2g eclipse spyder 5 spoke chrome rim.Also was wondering what kind of fitment issues ill have to deal with putting them on a 91 talon tsi awd/:talon:
I have the same thing you can run 225 with the tires slightly overhanging the rims, take it to a tire shop and try different sizes. You can search for other threads pertaining to this but i have the same set up on my 92 awd talon and i am thinking of getting wider rims and some fat lips on them.
2g Eclipse
Bolt Pattern: 5x114.3 (5x4.5)
Offset Range: 35 to 45
Wheel Size Range: 14x6.0 to 20x8.0
OEM Tire Size (Front): 195/70-14 (195x630 mm)
Max Tire Dimensions: 235x655.0
1g Talon
Wheel Size Range: 16x6.0 to 20x8.0
OEM Tire Size (Front): 205/55-16 (205x632 mm)
Max Tire Dimensions: 235x657.0
Enjoy
it all depended on what model or trim level you got. Base model 2g had 14" steelies. many RS got the 14" alloy. GS got 16" alloy rims. GST got 16" alloys and the GSX got 17" alloys. I am sure thats not the only combination available but it is the average or common setups.
Terry
BTW, just to clear things up. The info posted can be found on www.bigwheels.net. You will be able to see that the info posted is exactly what they post.
I don't pretend to know everything and will only post from reputable sources of info...they are one.
I know there are differences with stock years. This give you the WHOLE scope.
Have a good night.
  • Wanted 6 bolt NT water pipe
    • chrisman287
