For Sale 2g 800hp+ part out
Cynxe
263
6
Feb 19, 2015
Ottumwa, Iowa
Part out have tons of parts and lots pics. PM or text (preferred) me if you would like more information have receipts for everything that was purchased new. Or if interested in everything can buy all together. Most prices are shipped and add PayPal fees!
641-629-6790
Manley turbo tuff rods with 625 rod bolts and 0.020 Weisco HD 1400 pistons 9.0 compression with new rings ~8k miles but very good condition SOLD!
Bnib ARP main studs SOLD
Bnib ACL 7 bolt oil pump SOLD
Kiggly HP beehive springs low miles SOLD!
Kiggly HLA SOLD!
AEM Tru time cam gears only mounted $210 shipped
AEM EMS v1 BNIB never plugged in SOLD
SLS tubular manifold T3/ 38mm vband port $600 shipped
ACL Tri metal rod and main bearings $100 shipped
Top line 3g revised Lifters SOLD
Bnib STM balance shaft delete kit SOLD
Bnib Cometic MLS head gasket SOLD!!
Bnib STM turbo feed from head for pte BB $25 shipped
Bnib supertech valve stem seals $15 shipped
Bnib OEM gaskets and seals (intake, oil filter housing, rear main, oil cap, cam seals) SOLD
Bnib OEM 2g oil pump pickup tube SOLD
OEM bnib 2g hydrologic timing tensioner SOLD
2g AWD OEM flywheel with southbend SS-x pressure plate and segmented full ceramic clutch ~3k miles on clutch and flywheel resurface $500 shipped
1997 AWD trans unknown miles always been good to me no issues would prefer not to ship will come with OEM Tob with 3k miles and starter plate and flywheel cover. Used redline cocktail for fluids since owned. $400 + shipping if you need
1997 transfer case unknown miles no issues no noise used redline fluids $100 + shipping
1997 AWD shell with 73xxx miles has 4 point weld in cage, black and tan interior, driver seat is a fixed back scat procar has sparco 4 point harness. Has Evo X front brembo calipers with ferodo ds2500 pads. STM abs delete kit(full stainless lines up front) brake master has been upgraded to a bigger 3g eclipse master with jmf cap. Braided tank to rail line 255 in tank with Bosch 044 inline fuel pump was ran car ran on e85. Shell also has lsd rear end and Tein basic coilovers solid shifter base and shifter cable bushings speed density with gm style Omni 4 bar battery relocated to rear and engine harness tuck with fuse box relocated behind front bumper cover SPAL electric rad fan quarter panel needs paint work. Bring your own wheels. $1700 obo
TEXT PREFERRED
641-629-6790
