2000 rpm idle
9dsm5
Mar 10, 2008
hollywood, Florida
i have a 2g with a six bolt swap my idle starts out at 1700 rpm then warms up and jumps up to 2000 rpm . im getting fuastrated but dont wanna give up please help :dsm:
This one can be quite the tricky problem. Have you checked the the easy checks (throttle cable adjustment, maf (mass air flow sensor) plugged in, iac (idle air controller) plugged in)? The last 6 bolt swap I did, needed a fair amount of "adjusting", and a new iac. We used an air fuel controller, and a snap on scanner. If you have access to a scanner, check desired and actual readings on maf, iac, and idle. By comparing desired and actual, you may be able to catch you're culprit. In reality, with a car that has many different sensors, wires, and computers controlling everything, makes it hard to diagnose. I wish i could be more help on this one. Its hard to say without "experiencing" it first hand.
I just realized i didn't put vacuum leaks in there. Vacuum leaks can be hell. A smoke machine helps.
  • For sale 1g 4 BOLT Manual LSD Rear Differential
    1G 4 BOLT Manual LSD Rear Differential $225 + shipping & paypal feesYou must be registered to...
  • For sale 2g NEW STM Water Pump Block Off Plate
    NEW 2G STM Water Pump Block Off Plate $35 + shipping & paypal fees* these are $49 onlineYou...
  • For sale 4G63 NEW Greddy Shift Knob
    NEW Greddy Shift Knob $50 + shipping & paypal fees* these are $90 onlineYou must be...
  • Wanted 2g WTB CLEAN HVAC PARTS
    Good condition , clean please no rodent infestation
    • ames905
  • Wanted 2g MB914045
    I need a driver door trim piece.
    • T’sGST’s
