2 inch drop 17 inch rims camber kit?
Status
Not open for further replies.
NjDSMforLife
Nov 14, 2011
waretown, New Jersey
Im about to order the Megan Racing Lowering springs 2inch drop in the front 2inch drop in the back i have 215/50/r17 will i need a camber kit? if so how long can i last before i need one
Yes, you will need to either purchase a camber kit or use the DIY longer bolt and washer method to correct the camber.
One argument against doing the camber kit ... or even getting it aligned ... is that you might want to take the springs off the car after a few miles. But if you keep the springs, yes, you'll need a rear kit and an alignment. You will be doing serious damage to your rear tires until you do this, because your rear camber and toe, in particular, will be waaaay off.
Just post your questions in any of the numberous threads on the topic. We don't need a new thread on it.
Locking this, since you decided it would be a good idea to start a nearly identical one. :rolleyes:
Status
  • Wanted 6 bolt NT water pipe
    • chrisman287
