1g Head ID and 1g CAM ID
GSXeclipsePSI
563
7
Jul 7, 2003
New Port Richey, Florida
Hey, I took my head to a shop to have it checked out. They fixed my head instead and now I got a used head back in exhange.
Now I'm not sure if they gave me the correct head with maybe a worse cam set up.
I had a 6bolt out of 91 5speed.
Now I got a head with a plug in the CAS part and also I have CAM ID marks of (A)Intake and (C)Exhaust.
Could somebody tell me what head I may have and if my CAM set up with my prior head was better? Cause if this head aint my head or better, I want my better or same, not worse.
I noticed on the head so far that the old turbo oil supply line port is got a smaller port. The other question is on this head the gasket for my intake manifold has like 1/2 inch of space at the bottom, link the intake manifold gasket if bigger then head intake ports... Is this normal and didn't notice it b4.
thanks
kendel
ok, so far I found out by a link I was PM'ed that I have 252/252's now... or A'C' Cams. Now what motor and year did that come from and 2nd what were the cames I had in my 91 5sp turbo?
