1g Fuel trims really high
skibumexicano
41
Mar 4, 2004
Johnsburg, Illinois
Hey everyone...I've got a 92 GSX and have the basic mods. However i dont have an AFC. For awhile now i've been having a problem with my fuel-trims. All my fuel trims are at 139.8% according to MMCD. When i reset my computer, they all go back to 100% and after about 2 weeks, they are back at 139.8%. I think it's either a bad 02 sensor or because i hacked my MAS! Either way guys...Any input would be greatly apprecaited...Thanks..Dan
How much did you hack the mas? All you can do is pull the lower honeycomb without fuel control and even then, trims will be a little over 100% At 139%, that is maxed. If you only removed the lower hc, you probably have a vac leak somewhere. Do a boost leak test to find it.
When i hacked it, i removed the lower HC..After i hacked the MAS it all went to hell! I'm just running out of ideas...I need an AFC to correct it!
Well...looks like I've stumbled across another 1g mas..I'm gonna put that lower HC into my MAS and see what happens..I replaced my 02 sensor and nothing changed!
