DSMboostin15
- 502
- 6
- Sep 1, 2005
Dubuque,
Iowa
I have to replace my passenger rear caliper since it is sticking on my '91 TSI AWD with ABS and I just want to make sure that the bleeding process is the same for ABS and non-ABS cars. The FSM doesn't show a different process, just the one process similar to bleeding the clutch system.
Another question, since I'm just replacing the rear caliper and not removing anything else, do I have to specially bleed the ABS unit or will it just bleed when I bleed the system? Again, the FSM doesn't show anything for the ABS, just the generic bleeding process and everything I've found on here is for non-ABS cars.
If anyone has any tips, advice, etc., please let me know since this is one of the most important systems on the car. Thanks.
