spoolingreen20
- 46
- 0
- Jul 19, 2005
Youngstown,
Ohio
1996 Eagle Talon Tsi AWD (automatic). It has around 143,000 miles on the body. It has a clean title. I have had it in my garage for some time now stripped down being built for racing. I am looking to sell it due to the fact that Im going to be expecting an addition to my family. Im standing on $5000 right now. MAKE ME AN OFFER!! EVERYTHING MUST GO! PLEASE NO REQUESTS FOR PARTING OUT. There is about $7000 in brand new performance parts with about $2000 in new Mitsu parts. I have all receipts. I also have a handful of DSM parts both stock and aftermarket that I will throw in with this package. I need to unload all of my DSM parts. If you are interested I have a ton of pics so message me if you wish to see them. It is on Craigslist now 1996 Eagle Talon TSi AWD race project. The car does not have any wheels and will need a pair of 17's to fit a DSM and a trailer to haul it out.
Here is a list of the current condition of the car:
Front suspension-
Willwood brake kit with Willwood braided ss lines
Tein SS coil overs with pillow mounts
Energy suspension poly bushings kit
Brand new Mitsu upper control arms
RM Racing sway bar (poly bushings)
Brand new Mitsu sway bar endlinks
New tie rod ends
Brand new Mitsu lower control arms
Stock steering rack (original)
Brand new Mitsu hub bearings
Driveshaft Shop front shafts
Rear suspension-
Brand new Mitsu control arms
Brand new Mitsu rear calipers
Russel SS braided lines
Brand new parking brake cables
Brand new Mitsu sub frame
Driveshaft Shop 1000HP shafts with Driveshaft Shop rear hub bearings
New drilled rear rotors
RM Racing swaybar (poly bushings)
Brand new Mitsu brake shields
Ingalls camber kit
Rear diff repainted, new vent, new right and left seals, new oem bolts
Body-
VIS CF front fenders
VIS CF hatch
VIS Hood
Brand new OEM 97-98 style Talon front bumper (primered) w/new black Eagle badge
After market OEM style Talon headlights
Wheel wells reconditioned and undercoated
Brand new Mitsu Rear bumper support mounts
New bumper support
Stock OEM rear bumper cover
Rear undercarriage reconditioned(rust scrapped away and coated with por 15) undercoating applied
Engine bay repainted (shock towers in good shape, core support still solid)
1996 OEM side skirts
Fuel delivery-
Brand new Mitsu gas tank cover
Reconditioned gas tank straps
OEM stock gas tank
Brand new Mitsu pump sending unit
Brand new Mitsu gauge sending unit
Brake system-
All Brand new Mitsu brake lines
Brand new Mitsu (painted red) Non ABS proportioning valve
Drivetrain- not installed
1996 AWD automatic transmission (140,000 miles) with stock converter
1g used transfer case
Driveshaft shop aluminum center shaft
OEM stock short shaft to rear diff with new Mitsu carrier bearing and yolk installed
Engine- not installed
1991 turbo motor with around 100,000 miles on it (balance shafts removed otherwise stock) I owned the car it came out of and it ran good with a 16g. Has small front cover oil leak.
Slowboy aftermarket oil pan.
Stock internals.
Polyurethane motor mounts
1995 ECU (socketed but no chip)
Fluidyne aluminum radiator
Interior-currently gutted and was being setup for race
Front dash repainted black with OEM black new buttons/switches to match
OEM gray door panels (not installed)
OEM trim painted in black (not installed)
Front suspension-
New tie rod ends
Rear suspension-
Ingalls camber kit
Body-
VIS CF hatch
VIS Hood
New bumper support
Fuel delivery-
OEM stock gas tank
Brake system-
Stock internals.
