1990 Tsi AWD Time Capsule Maintenence
rastmp
54
Jun 15, 2008
Vernon, Connecticut
Hey Everybody,
So I found this 1990 Cherry Red Talon Tsi AWD in original/mint condition with 33k original miles.
Car is 100% stock.
A car collector kept it in a garage for 18 years under a carcover...
Here is my issue where I need help:
1. car sat for so long the original tires had dead spots in it(replaced)
2. gaskets are ROCK hard and break like glass...does this indicate the head gasket needs to be replaced?
3. original belts (cracked)
4. Gas tank rusted from inside (replaced with new OEM)
5. fluids are new/replaced
Is there anything else that needs replacing due to age and car not running for so long?
Thanks in advance
Looks like a beautiful talon. Did the owner at least start it regularly if not I would definitely change all the belts including timing components and do the basic maintenance before firing her up. Also check the compression for any worries of head gasket and pistons.
