16G on stock fuel?...
well first off it would be pretty well impossible to run at 4 or 5 pounds, unless you swapped out the wastegate actuator. Secondly, just run at stock boost ~10psi, you'll be fine.
Yeah, absolutely dude... run the stock boost with that turbo. You will experience signifigantly more turbo lag, but other than that, have fun. :thumb:
They nailed it. I did an Evo III swap and ran a while without any fuel mods. I also ran 12 psi, and didnt experience any fuel cut. If your really worried, just get a $90 fuel pump and DIY.
WhiteCharisma said:
is it possible to run a big 16G on stock fuel, at very low boost, 4 or 5 pounds?...
:dsm: :dsm: :dsm:
you can run up to 15psi with no problems, if you hit fuel cut just turn down the boost...
great...i wanted to know because my stock turbo is shot and i only have enough money for the turbo
thanks guys...
what is the best 16G on the market for a good price?
the evoIII 16G?...
:dsm: :dsm: :dsm:
Your gonna be ####y footing that evoIII if it creeps. Life will suck until you get fuel mods. Intercooler helped me out ALOT after the fuel mods.
thanks guys...
the evoIII 16G?...
:dsm: :dsm: :dsm:
Were in the same boat right now (shot turbo)and only enough for a new one LOL.
EDIT
Got mixed up between two different turbos.
