.020 bore with evo pistons?
yepes281
971
Mar 22, 2009
H-Town, Texas
As the title states, can i used 1g rods with Evo IX pisotons on a motor bore .020 over?
Evo pistons are 85mm just like DSM pistons. If you bore the motor .020, then you need a piston that is .020 over.
You might be able to buy EVO replacement pistons that are 85.5mm though.
For the cost of those, I'd rather put up the extra $200 and pick up a set of new Eagle/Wisecos.
Im trying to save as much as i can, so i am also looking for a used set of Eagle/Wisecos. The evo just isnt a bad deal at all, and i like the compression ratio. But would going with used piston and/or rods be a bad idea?
I wouldn't run a used set of OEM pistons because their so cheep new.
Rods however - you should be able to find a set of 1G Bid Rods online or at a junk yard for pretty cheep. 2.0L 6bolt N/A's have 1G Big Rods in them.
