The Never Ending Build
- Ownership Status
- Currently Own
- Year
- 1991
- Model/Trim
- Eagle Talon TSi AWD
- Drivetrain
- AWD
- Transmission Type
- Automatic
- Build Type
- Street
- Mods-Bolt-on
- Morrison large runner xona v band manifold and downpipe
Xona 9564s turbo .82 vband tial housing
JMF 1g bumper brace
Tial 44mm wastegate
Tial bov
STM short route 3” intercooler
Thermal R&D 3” exhaust for street
Morrison side exit exhaust for track
Rebuilt drive shaft
BBS 16x6 rims
Firestone Indy 500 FireHawks
Jegs drag wheels
M&H 26/8.5-15 drag tires
AEM wideband
Auto meter boost gauge
BC racing coilovers
Fuel lab fuel filter
Jegs marine battery relocation kit
Vibrant vacuum distribution block
Raceart billet map sensor holder
Custom CAS cap
Audi electric brake vacuum
3” intercooler piping
- Mods-Engine
- Head
Kelford 280r cams
Arp head studs L19
Kiggly HLA
Supertech black nitrate VALVES
AEM gears
Kiggley high pressure springs SS-HP 1030
Gsc valve SEALS
GSC lifters
Stock rockers
Magnus drag intake
Ross throttle body
Mustang tps sensor
SCE Athena head gasket
Block
Vader 156mm solid rods 22mm pin w/ arp 2000 bolts
Coated Kings bearings
ACL race main bearings
Arp main bolts
New oem oil pump straight cut gears
Balance shaft eliminated
Kiggly girdle
Kiggly 6 bolt flex plate
Wiseco HD stroker pistons 85.5mm
FUEL
Aeromotive fuel pressure regulator
An8line out
An8 line in
2000cc ID INJECTORS
Aeromotive fuel filter e85 ELEMENT
E85 Continental GM sensor
Magnafuel 750 pump
Nitrous outlet system
- Mods-EMS & Logging
- Haltech 1500, auto meter mechanical oil pressure gauge, wideband, temp gauge, boost gauge
- Mods-Drivetrain
- Trans AARON GREGORY BUILT
Forced4 shift box
IPT SHIFT KIT WITH SPRING
KIGGLY 6 disk clutch (50% more 3rd) basket
Raysbestos upgraded basket
Borg upgraded basket
Valve body upgrades
PRECISION STALL#6 (Jeff bush)
Hurst pro Matic 2 shifter
Derick Geedey Tranfer case billet brace
Hurst pro matic II shifter
Rebuilt stock axles front
A-1 CVTECH rear axles
- Mods-Handling
- Volk rear upper arms
Volk rear lower arms
Boostedfab mustache bar
Natfab tubular trailing arms
BSFAB 3 pc cross member
B&M trans cooler
Setrab oil cooler an10 line
poly rear subframe bushings
Poly sway bar bushings
Poly front control arm bushings
- Parts Wishlist
- Mechanical fuel pump, 8.5 cage, drag seat
- Background
- I’m from Indy and drove to Michigan to get the car, it’s 95% rust free, and original
I am just reliving my childhood, in 1999 I owned a beautiful 1998 GSX that was mint but at the time I was young and couldn’t afford a happy meal!
I’m sure everyone has been there at 18 years old!
Bought this 91 talon in late 2019 to restore, I ended up going completely overboard on the car, turning it into what you see now in the pictures I wanted to make it to where everything could bolt back up in the car be stock again!
I had never build an engine until this moment! So there was a huge learning curve as far as mechanical abilities! I have had some amazing help along the way from people local and state to state!
